Dear LAMMPS Users,
I hope this message finds you well.
I am a beginner with LAMMPS and currently attempting to replicate the results of a study that performed structure optimization and phonon dispersion calculations for naphthalene (J. Chem. Theory Comput. 2020, 16, 2716−2735).
For the structure optimization, I am using the primitive unit cell (1×1×1) of the experimental structure as the simulation box, applying periodic boundary conditions, and optimizing the lattice constants with the box/relax tri
method. While the results do not match the values reported in the paper exactly, likely due to differences in force fields and limited information provided in the study, I have obtained very similar lattice constant values.
To calculate the phonon dispersion using the frozen phonon method, I created a supercell from the optimized primitive unit cell using the replicate
command. However, I noticed that when expanding the cell in any direction, some atoms experience nonzero forces. These forces range from what I consider sufficiently converged values to about 0.1 kcal/Å.
From my understanding of physics, if the primitive unit cell is properly optimized, the resulting expanded supercell should maintain uniform structural optimization. While I expect minor errors during the expansion process, I find the observed magnitudes of force to be unexpectedly high.
I would like to seek advice from the community regarding the following questions:
- Is it appropriate to perform structure optimization for the primitive unit cell of molecular crystals using LAMMPS?
- If the answer to (1) is yes, why might forces appear on atoms when the optimized structure is expanded into a supercell? Are there any ways to address this issue?
Thank you very much for your time and insight. I greatly appreciate your support.
naphalene.input (1.4 KB)
naphtalene.lmp (20.1 KB)
log.lammps (8.1 KB)
opt_force_primitive_dump_final.dat (3.4 KB)
no_opt_force_no_pbc_10_10_10_dump_final.dat (6.4 KB)
S.H.
