Using ScriptTask.from_file(yaml_file) throws "required parameter script not specified"
In my script, these two lines:
yamlcubit =
“/home/Synclesis/Projects/STTR_A15A-T004/Sandboxes/dshaw/fireflow/pywrappers/firetasks/cubi_task.yaml”
cubit_firetask = ScriptTask.from_file(yamlcubit)
throw the following error:
File
“mead.py”, line 127, in
File “/usr/lib64/python2.7/site-packages/fireworks/utilities/fw_serializers.py”,
line 293, in from_file
return cls.from_format(f.read(), f_format=f_format)
File
line 261, in from_format
yaml.load(f_str, Loader=Loader)))
File
line 163, in _decorator
m_dict = func(self, *new_args, **kwargs)
File “/usr/lib64/python2.7/site-packages/fireworks/core/firework.py”,
line 101, in from_dict
return cls(m_dict)
File
“/usr/lib64/python2.7/site-packages/fireworks/core/firework.py”, line
51, in call
raise ValueError("{}: Required parameter {} not
specified!".format(cls, k))ValueError: <class ‘fireworks.user_objects.firetasks.script_task.ScriptTask’>:
Required parameter script not specified!
The yaml file looks like:
spec:
_tasks:
    - _fw_name: PyTask
      func: update_cubit.main
      stored_data_varname:
“cubit_metadata”
      kwargs:
{“cubitfile”:
“/home/Synclesis/Projects/STTR_A15A-T004/Sandboxes/dshaw/fireflow/inputs/testbox.py”,
“var_names”: {“1”: “deltay”, “0”:
“deltax”, “2”: “deltaz”}, “errfile”:
“cubit.err”, “var_values”: "
1.14999999999999991e-01 1.04999999999999996e-01
9.50000000000000011e-02 \n", “exofile”:
“/home/Synclesis/Projects/STTR_A15A-T004/Sandboxes/dshaw/fireflow/inputs/testbox.exo”}
_pass_job_info: True
Now, I’ve been going through the documentation trying to sort this out but have not had any success yet. Does anyone know what is causing this ValueError and, more importantly, what I can do to fix it? If you need any more info from me. just let me know.
Dan
I am pretty sure you are trying to create a Firework, not a Firetask (and in particular, definitely not trying to create a ScriptTask since your YAML file is about a PyTask)
So I think what you need is:
cubit_fw = Firework.from_file(yamlcubit)
yamlcubit =
File
File
File
return cls(m_dict)
File
51, in call
spec:
_tasks:
    - _fw_name: PyTask
“cubit_metadata”
      kwargs:
{“cubitfile”:
Dan
You received this message because you are subscribed to the Google Groups “fireworkflows” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To post to this group, send email to firewo.[email protected].
Visit this group at https://groups.google.com/group/fireworkflows.
To view this discussion on the web visit https://groups.google.com/d/msgid/fireworkflows/edb091a3-ae90-4416-85e6-b24c02761a4d%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Anubhav
It worked, I’ve got a quick follow-up. I create a firework.from_file 5 times and each time the id=-1. How do I set it up so that to generate unique IDs?
Dan
yamlcubit =
File
File
File
return cls(m_dict)
File
51, in call
spec:
_tasks:
    - _fw_name: PyTask
“cubit_metadata”
      kwargs:
{“cubitfile”:
Dan
To post to this group, send email to [email protected].
Anubhav
