when you switch to a hybrid pair style, the format
for providing the pair coefficients changes. each set
of parameters needs to be prefixed with the style it
applies to. i am not sure if you can use the Pair Coeffs
section in a data file at all with that, but for certain
not without changes.
When questions like the one below are posted, responses like the one
just offered by Axel are well deserved. Those who are turning to the
list as a vehicle to solve their assignments without first trying
their best do nothing but compromise the quality of this service by
potentially discouraging knowledgeable people from participating due
to the trivial nature of the questions being asked. Please community,
keep that in mind at all times.
Carlos
If you have one pair coeff assigment per I/I atom type you
can define pair coeffs for the pair hybrid style in the
data file. The syntax for doing so is essentially the
same as in the input script. It is a different syntax that
the usual pair coeff command, and is described on the
pair hybrid doc page. In your case you appear to be
using hybrid/overlay, which means you want to assign
multiple pair coeff commands to each pair of atom
types. You have to do that in the input script.
