Hi...
I am trying to fix a few installation issues in a 64-bit Mac machine (Mac OS X Server 10.6.8). I also encountered the same problem in the previous version (openkim-api-v0.1.0).
I was able to run the Makefile in $KIM_DIR. Then, I tried running ./run_all_tests under $KIM_DIR/TESTs to see if everything is alright. While some of the tests were successful, I got some segmentation fault error messages for many tests. Please see the attached file (all_tests.out) that I obtained from the following sequence of commands:
all_tests.out (79.5 KB)
