Greetings,
I am trying to utilize fix qeq/reax command with non-ReaxFF potential. In my liquid-solid system, TIP4P-Ew is for water-water interaction, EAM is for solid-solid interaction. lj/cut/coul/long is for water-solid interaction. And I want to use fix qeq/reax to calculate the charges each timestep. But I kept got the error message as listed below I wonder what the problem could be.
"[HESS112d:18649] *** Process received signal ***
[HESS112d:18649] Signal: Segmentation fault (11)
[HESS112d:18649] Signal code: Address not mapped (1)
[HESS112d:18649] Failing at address: 0x200f19ea8
[HESS112d:18649] [ 0] /lib64/libpthread.so.0() [0x31f060eeb0]
[HESS112d:18649] [ 1] lmp_openmpi(_ZN9LAMMPS_NS10FixQEqReax9compute_HEv+0xf8) [0x77adb8]
[HESS112d:18649] [ 2] lmp_openmpi(_ZN9LAMMPS_NS10FixQEqReax11init_matvecEv+0x16) [0x77b586]
[HESS112d:18649] [ 3] lmp_openmpi(_ZN9LAMMPS_NS10FixQEqReax9pre_forceEi+0xc6) [0x77d3c6]
[HESS112d:18649] [ 4] lmp_openmpi(_ZN9LAMMPS_NS6Modify15setup_pre_forceEi+0xce) [0x51bd2e]
[HESS112d:18649] [ 5] lmp_openmpi(_ZN9LAMMPS_NS6Verlet5setupEv+0x174) [0x87b284]
[HESS112d:18649] [ 6] lmp_openmpi(_ZN9LAMMPS_NS3Run7commandEiPPc+0x250) [0x70c7e0]
[HESS112d:18649] [ 7] lmp_openmpi(_ZN9LAMMPS_NS5Input15execute_commandEv+0xa75) [0x509445]
[HESS112d:18649] [ 8] lmp_openmpi(_ZN9LAMMPS_NS5Input4fileEv+0x616) [0x50b316]
[HESS112d:18649] [ 9] lmp_openmpi(main+0x49) [0x56df89]
[HESS112d:18649] [10] /lib64/libc.so.6(__libc_start_main+0xfd) [0x31efa1ee5d]
[HESS112d:18649] [11] lmp_openmpi() [0x4848f9]
[HESS112d:18649] *** End of error message ***
[HESS112d:18647] *** Process received signal ***
[HESS112d:18647] Signal: Segmentation fault (11)
[HESS112d:18647] Signal code: Address not mapped (1)
[HESS112d:18647] Failing at address: 0x202b2c690
[HESS112d:18647] [ 0] /lib64/libpthread.so.0() [0x31f060eeb0]
[HESS112d:18647] [ 1] lmp_openmpi(_ZN9LAMMPS_NS10FixQEqReax9compute_HEv+0x31d) [0x77afdd]
[HESS112d:18647] [ 2] lmp_openmpi(_ZN9LAMMPS_NS10FixQEqReax11init_matvecEv+0x16) [0x77b586]
[HESS112d:18647] [ 3] lmp_openmpi(_ZN9LAMMPS_NS10FixQEqReax9pre_forceEi+0xc6) [0x77d3c6]
[HESS112d:18647] [ 4] lmp_openmpi(_ZN9LAMMPS_NS6Modify15setup_pre_forceEi+0xce) [0x51bd2e]
[HESS112d:18647] [ 5] lmp_openmpi(_ZN9LAMMPS_NS6Verlet5setupEv+0x174) [0x87b284]
[HESS112d:18647] [ 6] lmp_openmpi(_ZN9LAMMPS_NS3Run7commandEiPPc+0x250) [0x70c7e0]
[HESS112d:18647] [ 7] lmp_openmpi(_ZN9LAMMPS_NS5Input15execute_commandEv+0xa75) [0x509445]
[HESS112d:18647] [ 8] lmp_openmpi(_ZN9LAMMPS_NS5Input4fileEv+0x616) [0x50b316]
[HESS112d:18647] [ 9] lmp_openmpi(main+0x49) [0x56df89]
[HESS112d:18647] [10] /lib64/libc.so.6(__libc_start_main+0xfd) [0x31efa1ee5d]
[HESS112d:18647] [11] lmp_openmpi() [0x4848f9]
[HESS112d:18647] *** End of error message ***
My input script is pasted below
atom_style full
bond_style harmonic
angle_style harmonic
pair_style hybrid eam lj/cut/coul/long/tip4p 1 2 1 1 0.125 9.0 lj/cut/coul/long 9.0
read_data test1.data
pair_coeff 1 1 lj/cut/coul/long/tip4p 0.00705684 3.16435
pair_coeff 2 2 lj/cut/coul/long/tip4p 0.0 0.0
pair_coeff 1 2 lj/cut/coul/long/tip4p 0.0 0.0
pair_coeff 3 3 eam Au_u3.eam
pair_coeff 1 3 lj/cut/coul/long 0.08602 2.95
pair_coeff 2 3 lj/cut/coul/long 0 0
kspace_style pppm/tip4p 10e-6
group water type 1 2
group wall type 3
neigh_modify delay 5
velocity all create 0.0 1372109 dist gaussian rot yes units box
fix 1 water shake 0.0001 10 0 b 1 a 1
fix 2 computation nvt temp 400 400 0.1
fix 3 all qeq/reax 1 0.0 10.0 1.0e-6 param.qeq
thermo_style custom step pe ke etotal vol lx ly lz
thermo 1000
dump 1 all custom 100000 dump1.lammpstrj id mol type q x y z
timestep 0.001
restart 100000 system_restart
run 1000000
Thanks a lot for your time and effort!
Regards,
Kira
