Van der Waals interlayer potential of graphenite structures: Lebedeva model
Dears,
As I noticed we have in LAMMPS one more interlayer potential for graphene, Kolmogorov-Crispy.
And I tested one even more, which I call for convenience Lebedeva potential.
I did implement it in LAMMPS. However, was it done correctly? The potential itself seems to work as it should, I had another way to check it out. I am less certain if derivatives in the code are implemented correctly.
I attach a tar file. It contains PDF with the equation itself, calculating derivatives, links to original articles of Lebedeva et al.
TAR contains also C code, lebedeva.cpp and lebedeva.h, as well potential file CC.Lebedeva, with parameters (taken from the original article).
All this should be used from LAMMPS scripts in the same way as kolmogorov-crispy.
Would someone be interested / willing to have a look there?
Regards,
zb.
P.s.: Of course, if all that works properly, I would not mind the code to be included in distribution.
lebedeva.tar (80 KB)
Hi - thanks for working on a new potential. However, I doubt others
are going to check your work. Re: derivatives being correct, if you
can run with good energy conservation, that’s typically an indication
your forces are consistent with the energy.
Why you are confident it is correct, I suggest you submit all the
files as a pull request on LAMMPS GitHub, and they will be
examined for inclusion in LAMMPS.
