Velocity of certain region
I am a new user of Lammps. I want to calculate velocity of a certain region by following formula, V = const value * z position of atom. Can anyone please suggest, which command should I use to determine the velocity. Thanks.
Do you mean calculate the current velocity, or
set the velocity to some desired value?
You can calculate an average velocity
for a one or more sets of atoms (e.g. a region) via the
compute vcm/chunk command.
You can set the velocity of a group of atoms
via the velocity command.
Thanks for the reply.I want to set the velocity to some desired value. The main issue for me is to calculate the z position of the atoms, as I want to specify the velocity according to the z position. the formula i want to use is v= const * z position of the velocity.Can u pls suggest how to determine the z poisition and use it for setting the velocity. Thanks.
Sorry the formula is v = Const * z position of the atom.
you should be able to use the velocity ramp command for your case.
