i have prepared my model of cnt and polymer using moltemplate.
but when i attempt to read the data file using vmd by the command
“topo readlammpsdata file.data full”
structure looks fine.
but when i used command
pbc wrap -compound res -all
CNT moves out from the polymer.
same problem happened when i run lammpstrj file in syntax
"dump cntpp all custom 1000 file.lammpstrj id mol type x y z ix iy iz
Help me sort-out the the issue.
thanks in advance
"topo readlammpsdata file.data full"
a) there is no issue outside of you not understanding pbctools.
pbctools does what you are asking it to do.
b) this is a VMD/pbctools issue and thus off-topic here.
