I am using the latest version of lammps (16th Feb 2016) and computing occupation in irradiation simulations in tungsten using the command
compute vacint cascade voronoi/atom occupation
While writing the output, after 36400 steps, the program crashes with the error:
APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
/home/maya/maya_lammps/lammps_debug_segfault
If I remove the occupation calculation, it works fine.
The input script for the programme is attached
Could you suggest where did it go wrong?
The segfault happens when i invoke dump 5, the printing of occupation of final cascade after 36400 steps.
Thank you
Maya
input_cascade_Dudarev_segfault (5.21 KB)
