wall boundary condition in dpd
Hi Dear lammps-users,
There is no documented prohibition against using wall/reflect and one of the DPD pair styles. There is this warning for rigid fix styles:
“A reflecting wall should not be used with rigid bodies such as those defined by a “fix rigid” command. This is because the wall/reflect displaces atoms directly rather than exerts a force on them. For rigid bodies, use a soft wall instead, such as fix wall/lj93. LAMMPS will flag the use of a rigid fix with fix wall/reflect with a warning, but will not generate an error.”
So, your choices are:
  1. Replace wall/reflect with fix wall/region with a cylindrical region.
  2. Explore exactly what you mean by “does not work”
  3. I suspect you mean that wall/reflect only handles planar walls. Back in the olden days, when LAMMPS was still FORTRAN, I put in a cylindrical reflective wall and wrote a paper on it:
A. P. Thompson, “Non-equilibrium Molecular Dynamics Simulation of Electroosmotic Flow in a Charged Nanopore,” J. Chem. Phys., 119, 7503 (2003).
Here is the FORTRAN code:
do i = 1,nlocal
rcyl = sqrt(rcsq)
vdotr = v(2,i)*x(2,i)+v(3,i)*x(3,i)
vsq = v(2,i)**2+v(3,i)**2
tc = (-vdotr+sqrt(vdotr**2+vsq*(rcsq-rsq)))/vsq
rcy = x(2,i)+tc*v(2,i)
rcz = x(3,i)+tc*v(3,i)
vdotrc = v(2,i)*rcy+v(3,i)*rcz
fac = 2*vdotrc/rcsq
x(2,i) = x(2,i)+tcfacrcy
x(3,i) = x(3,i)+tcfacrcz
v(2,i) = v(2,i)-fac*rcy
v(3,i) = v(3,i)-fac*rcz
Based on this, you could add your particular boundary condition to void FixWallReflect::post_integrate() in fix_wall_reflect.cpp.
Aidan
