Dear all
I set up a rigid ball, and when the force is applied to it, the ball moves, and I want to calculate its velocity equivalent. Here I ues fix rigid /nve command on the ball but a warnning came up
WARNING: Cannot count rigid body degrees-of-freedom before bodies are initialized (… /fix_rigid.cpp:1239)
I did not make this warnning disappear by following the methods in the LAMMPS manual.
velocity ball create 300.0 12345
run 0 # temperature may not be 300K
velocity ball scale 300.0 # now it should be
fix 2 ball rigid/nve single
I would like to ask how to solve this problem? Whether the presence of this Warnning affects subsequent results
