Hi, all, I found two warnings in my simulation; the information is below:
Special bond factors lj: 0 0 0
Special bond factors coul: 0 0 0
4 = max # of 1-2 neighbors
8 = max # of 1-3 neighbors
22 = max # of 1-4 neighbors
23 = max # of special neighbors
Special bond factors lj: 0 0 1
Special bond factors coul: 0 0 1
12 = max # of special neighbors
1280 atoms in group CNT
23 atoms in group ket11
24 atoms in group ket12
30623 atoms in group mket
1327 atoms in group CNTket-1
PPPM initialization ...
WARNING: System is not charge neutral, net charge = 0.03 (kspace.cpp:297)
G vector (1/distance) = 0.241562
grid = 54 54 27
stencil order = 5
estimated absolute RMS force accuracy = 0.000364241
estimated relative force accuracy = 1.0969e-06
using double precision FFTs
3d grid and FFT values/proc = 5200 1512
Neighbor list info ...
1 neighbor list requests
update every 1 steps, delay 10 steps, check yes
master list distance cutoff = 14
Setting up run ...
WARNING: Inconsistent image flags (domain.cpp:682)
Memory usage per processor = 14.4138 Mbytes
Step Atoms Tcnt Tket Press Volume PotEng KinEng TotEng E_long Lx Ly Lz Xlo Xhi Ylo Yhi Zlo Zhi
0 31903 388.15863 209.31861 -2368.8103 369333.35 2129901.6 20586.098 2150487.7 -29443.064
ERROR on proc 39: Bond atoms 8746 8747 missing on proc 39 at step 44 (neigh_bond.cpp:65)
what I guess is the bond atoms may be the reason for the nonzero net charge. At the same time, it causes the inconsistent image flags. If the problem is caused by this bonding, how can I fix that?
(bring the atoms closer or use fix_bond)
Haoxiang Huang
