Water in a box
Hello, I’m new to lammps and recently I’m trying to simulate water in a box and extract some thermodynamic information such as temperature, pressure and enthalpy from the system to generate a phase diagram later. Below is the script.
variable T equal 273.15+20 # temperature in Kelvin
variable A2m equal 1e-10 # Angstrom to meter
variable atm2Pa equal 101325 # Atmosphere to Pascal
variable N2mN equal 1e3 # Newton to milliNewton
units real
atom_style full
bond_style harmonic
angle_style harmonic
pair_style lj/cut/tip4p/long 1 2 1 1 0.1546 12.0
kspace_style pppm/tip4p 1.0e-4
pair_modify shift yes mix arithmetic
read_data conf.data
include PARM.lammps
dynamics
velocity all create ${{T}} 4928459 mom yes rot yes dist gaussian # give an initial temperature to the molecules
fix mynve all nve
fix myber all temp/berendsen {{T}} {{T}} 100
fix myshk all shake 1.0e-4 200 0 b 1 a 1 # maintain the shape of the water molecule
timestep 1.0
thermo 100
thermo_style custom step temp press etotal
run 10000
I’m not sure there’s a question here – but in the meantime please note that you should use backticks to “fence off” your input script
like this
so that the forum will format it properly as “source code”.
