what is wrong with charmm2lammps.pl program
Dear all:
I build tip4p water box using charmm program. Then I used charmm2lammps.pl program to build data file and input file. Checking the data file, I can see that it listed the bond type as 0 when using tip4p rtf and tip4p prm forcefield files in converting. When using the charmm27 forcefield files in combination with tip4p forcefield, it gave me mass for the second and third atom in the data file as 0.0. I know that is not true either. Can I know how to solve my problem? Thanks a lot.
LqZ
The following is the head of the data file built which showed 0 bond types.
500 atoms
500 bonds
125 angles]
0 dihedrals
0 impropers
3 atom types
0 bond types
0 angle types
0 dihedral types
0 improper types
-8.388 8.388 xlo xhi
-7.994 7.984 ylo yhi
-7.774 7.7 zlo zhi
Masses
1 1.008
2 15.9994
3 0
Pair Coeffs
1 0.0498 1.425438 0.0498 1.425438
2 0.1591 2.850876 0.1591 2.850876
3 -0 1.425438 -0 1.425438
Atoms
1 1 2 0 7.631 6.953 -6.863
2 1 3 -1.04 7.631 6.804 -6.844
3 1 1 0.52 8.388 6.372 -6.787
4 1 1 0.52 6.874 6.372 -6.787
2011/12/4 zhanglaura <[email protected]...>:
Dear all:
that won't work for LAMMPS.
you either don't understand the TIP4P water topology or misunderstand
the data file.
CHARMM builds an explicit four-site model, which won't work in LAMMPS.
the conversion is correct, though. however, what you have to do to do TIP4P
in water is to set up a TIP3P (i.e. a 3-site water), adjust the parameters as
needed and then use the special /tip4p potentials (for pair and kspace as
needed) to have the massless M site coordinates properly computed.
please have a look at the corresponding section of the LAMMPS manual:
Hi, Axel:
Thanks a lot for the help. I built a input file for tip4p water as following:
LJ system with NPT ensemble
units real
atom_style full
kspace_style pppm/tip4p 0.0001
read_data data.water1
timestep 0.1
pair_style lj/cut/coul/long/tip4p 1 2 7 8 0.3 8.0
pair_coeff 1 1 0.16275 3.16435
pair_coeff 1 2 0.0 0.0
pair_coeff 2 2 0.0 0.0
bond_style harmonic
bond_coeff 1 450.0 0.9572
angle_style harmonic
angle_coeff 1 55 104.52
timestep 0.1
dump 1 all atom 10 trajectory.lmptrj
fix 1 all shake 1e-6 50 100 a 1 b 1
fix 2 all nvt temp 300.0 300.0 1.0
thermo_style multi
thermo 100
restart 200 as-298-1.lammps as-298-2.lammps
run 800000
But I got the error as:
PPPM initialization …
ERROR: Bad TIP4P angle type for PPPM/TIP4P
No matter I used angle_style harmonic or charmm (with coeff changed accordingly), it can not work. So what should I do? Thanks a lot.
LqZ
Hi, Axel:
following:
# LJ system with NPT ensemble
units real
atom_style full
timestep 0.1
bond_style harmonic
timestep 0.1
thermo_style multi
thermo 100
run 800000
PPPM initialization ...
the error is about angle *type* not angle *style*.
you didn't read the documentation correctly
and thus your pair style definition is wrong.
re-read the documentation and correct your input.
Hi, Axel:
Thanks a lot for your help. I figured out how to solve the angle error. With my progress, I found that my new problem was on atom type not found, which is related to the order to otype and htype listed in the data file based on my searching online. I checked my original file (tip3p water data file from charmm) and the new data file from charmm2lammps.pl. I was surprised to see that the order of otype and htype was switched. The original tip3p water data file from charmm is like following:
1 1 TIP3 OH2 -31.04245 -30.65189 -31.04309 BOX 1 0.00000
2 1 TIP3 H1 -30.28342 -31.23963 -31.04309 BOX 1 0.00000
3 1 TIP3 H2 -31.80151 -31.23962 -31.04309 BOX 1 0.00000
4 2 TIP3 OH2 -27.93813 -30.65183 -31.04309 BOX 2 0.00000
5 2 TIP3 H1 -27.17910 -31.23957 -31.04309 BOX 2 0.00000
6 2 TIP3 H2 -28.69719 -31.23956 -31.04309 BOX 2 0.00000
Then in the new data file from charmm2lammps.pl, it has following:
Masses
1 1.008
2 15.9994
Pair Coeffs
1 0.046 0.4000135 0.046 0.4000135
2 0.1521 3.150574 0.1521 3.150574
Atoms
1 1 2 -0.834 -13.339 -14.101 -15.701
2 1 1 0.417 -12.67 -14.677 -16.098
3 1 1 0.417 -14.141 -14.388 -16.161
4 2 2 -0.834 -9.29 -12.943 -13.637
5 2 1 0.417 -8.34 -12.702 -13.502
6 2 1 0.417 -9.173 -13.712 -14.206
Is there any way to let the charmm2lammps.pl to output O as atom type 1 while H as atom type 2? Thank you very much.
LqZ
2011/12/5 zhanglaura <[email protected]...>:
Hi, Axel:
1    1 TIP3 OH2  \-31\.04245 \-30\.65189 \-31\.04309 BOX  1      0\.00000
2    1 TIP3 H1   \-30\.28342 \-31\.23963 \-31\.04309 BOX  1      0\.00000
3    1 TIP3 H2   \-31\.80151 \-31\.23962 \-31\.04309 BOX  1      0\.00000
4    2 TIP3 OH2  \-27\.93813 \-30\.65183 \-31\.04309 BOX  2      0\.00000
5    2 TIP3 H1   \-27\.17910 \-31\.23957 \-31\.04309 BOX  2      0\.00000
6    2 TIP3 H2   \-28\.69719 \-31\.23956 \-31\.04309 BOX  2      0\.00000
Masses
   1      1\.008
   2    15\.9994
Pair Coeffs
   1      0\.046  0\.4000135      0\.046  0\.4000135
   2     0\.1521   3\.150574     0\.1521   3\.150574
Atoms
   1       1     2    \-0\.834     \-13\.339     \-14\.101     \-15\.701
   2       1     1     0\.417      \-12\.67     \-14\.677     \-16\.098
   3       1     1     0\.417     \-14\.141     \-14\.388     \-16\.161
   4       2     2    \-0\.834       \-9\.29     \-12\.943     \-13\.637
   5       2     1     0\.417       \-8\.34     \-12\.702     \-13\.502
   6       2     1     0\.417      \-9\.173     \-13\.712     \-14\.206
why that?
this is not needed; all you need to do
is to adjust your pair style command...
axel
Hi, Axel:
I fixed the potential problem based on your former hint. My current input file is like following:
units real
atom_style full
pair_style lj/cut/coul/long/tip4p 1 2 1 1 0.125 0.3 8.0
bond_style harmonic
read_data water.lammps.data
timestep 0.1
thermo_style multi
thermo 100
run 800000
I got the error as:
G vector = 0.330885
grid = 20 20 24
stencil order = 5
RMS precision = 6.83088e-05
using double precision FFTs
brick FFT buffer size/proc = 22599 9600 10044
Setting up run …
ERROR on proc 0: TIP4P hydrogen has incorrect atom type (pair_lj_cut_coul_long_tip4p.cpp:484)
Based on my search online, it should relate to the order of Otype and Htype. But the Otype and Htype was switched after using charmm2lammps.pl program. So I am wondering what I should do to switch back the Htype and Otype order. Thanks a lot.
LqZ
Hi, Axel:
no you didn't fix it. you only fixed the bond and angle part.
the atom type mapping is still not correct.
units real
atom_style full
bond_style harmonic
timestep 0.1
thermo_style multi
thermo 100
run 800000
I got the error as:
G vector = 0.330885
grid = 20 20 24
stencil order = 5
Setting up run ...
you don't have to!! just use your brains.
it doesn't matter what atom type charmm2lammps.pl
assigned, but it *does* matter that you list the correct
atom type in your pair style command (which you don't)
