I am not very clear to the meaning of "Max Mem / Proc"
in the "GPU Time Info (average)".
Is it the maximal of GPU memory used by one CPU core?
Thanks in advance.
Kai Wang
Institute of Metal Research, CAS
Thanks in advance.
Kai Wang
If this is in the output for the GPU package,
then Mike can answer it.
Hi, Steve
Yes, it is in the output "GPU Time Info (average)" when using GPU package.
Kai Wang
It is the maximum memory used at one time on the GPU for data storage by
a single MPI process. - Mike
Hi, Mike
I'm not familiar with parallel computing.
May I do a further confirmation:
Does the "a single MPI process" mean one CPU,
so, if I use 2 nodes, 12 cpu, 1 gpu per nodes,
get 100MB Max Mem / Proc, does it mean
the maximal possible data storage on 1 gpu is
100 MB * 12 = 2400 MB ?
Or it is right if I monopolize these resource?
Thank you in advance.
Kai Wang
it is not the maximum memory available it is the maximum memory used.
the mpi processes are the concurrently executing instances of a program
at the o/s process level. often people launch the same number of mpi
procs as cpu cores. for n processes sharing a single gpu, each using x
units of memory space, you don't want n*x > available_gpu_memory.
- Mike
