I ran GCMC calculations (water adsorption in a mesoporous material).
When I read the dump file with ovito, everything is fine. the pore is centered.
Then, as the adsorption was not converged I restarted it.
However, this time if I read the second dump file, the whole structure is shifted (since the 1st step of the trajectories)
Regarding the structure, since the system is periodic in 3 dimensions it is not an issue. However, I shall perform MD after that and for post-processing the trajectories it is cumbersome. I guess I can “recenter” the system before the MD run, but I guess I missed something in my GCMC restart.
variable T equal 298 # initiale temperature, Kelvin
variable dt equal 1.0 # fs unit
variable Tdamp equal 100
variable seed equal 6354
variable mu index -8.1 # not used since pressure keywords in GCMC is used
variable P index 1.0e-04 # atm
variable disp index 0.5 # not used
variable tfac equal 5.0/3.0 # (3 trans + 2 rot)/(3 trans), from simon gravelle. Try without it
timer timeout 156:00:00 every 10000
read_restart MCM41.${T}K.${P}atm.restart.2000000
variable zlo equal zlo
variable zhi equal zhi
kspace_style pppm/tip4p 1.0e-5
region tube cylinder z 0.0 0.0 10.0 ${zlo} ${zhi}
# settings
group wat type 1 2
molecule h2omol H2O_TIP4P_2005.txt
compute twat wat temp
compute_modify twat dynamic/dof yes
fix mynvt wat nvt temp ${T} ${T} ${Tdamp}
fix_modify mynvt temp twat
fix myshk wat shake 1.0e-4 200 0 b 1 a 1 mol h2omol
# GCMC
fix mygcmc wat gcmc 100 100 0 0 54341 ${T} ${mu} ${disp} &
mol h2omol tfac_insert ${tfac} group wat pressure ${P} region tube shake myshk
# dynamically update default temperature ndof
compute_modify thermo_temp dynamic/dof yes
# for visualisation
dump mydmp all atom 100 dump.MCM41.${T}K.${P}atm.GCMC.lammpstrj
timestep ${dt}
thermo 100
thermo_style custom step temp press pe ke density atoms v_iacc v_dacc v_tacc v_racc v_nO
restart 100000 MCM41.${T}K.${P}atm.restart
run 3000000
