Not sure what the point of not putting
KSpace at the outer level would be,
since nothing is more outer?
i *do* want to put kspace at the outermost level, but i want to it
less frequently than the outer non-bonded calculations.
as i wrote, it works fine, if i don't split non-bonded into inner and outer.
This command specifies 4 levels, and you are asking that
sorry, but it doesn't. the numbers in the respa command are all 1
based not zero based.
KSpace be at level 3, not the outermost 4. Am I
missing something?
i am asking for 3 levels. level 1 being executed twice for every
evaluation of level 2
level 2 in turn being execute twice for every evaluation of level 3.
i'm assigning bond, angle, dihedral, improper and inner to level 1,
i'm skipping middle, assigning outer to level 2 and kspace to level 3,
which is the outermost level. but the code in respa.cpp doesn't allow
me to do the factor 2 between outer non-bonded a kspace. however,
i can run a factor 2 between pair and kspace, if i run all of pair together.
oops - I misread the doc page, that is 3 levels, not 4.
I think changing the test to level_kspace < level_outer
should be fine. Our thinking may have been that some
portion of the pairwise should be done with the KSpace
since they are complementary, but I don't think
it is a requirement. I see that the code will even
allow you to not put KSpace at the outermost level
(just throws a warning), which is what I thought you
were doing if there were 4 levels defined.
in fact, this kind of scheme is what people do in NAMD to get the best
performance.
that seems to be working fine, though.
i made some tests for that, too. e.g.:
