Hi @Alma. The short answer is that since NSW = 0
, it does not matter than ISIF
is set. VASP will not adjust the positions or cell shape/volume.
The input files are generated using Atomate, and in this particular case, it is a static calculation with INCAR settings found in pymatgen.io.vasp.sets.MPStaticSet
. You can see here that the static calculation takes the prior relaxation’s INCAR settings and “updates” them, including changing NSW
to 0 and IBRION
to -1. It does not alter ISIF
, so the ISIF
value from the prior relaxation job is still present in the INCAR. Not to worry though – ISIF
has no effect here.
