Hello lammps users. I am using the write data command in lammps to write out a data file after a simulation,
where I have also used the delete_atoms command in the simulation.
After the simulation, I tried to read the data file using read_data command (to carry out further simulation). I get the following error
" Unexpected end of data file (…/read_data.cpp:1053)"
But the data file seems to be fine. I tried to read the data file using topo tools and it works fine.
I have tried out the same thing with the write_restart command and tried to read it using the read_restart command, it works perfectly.
I have also tried, without using the delete_atoms command i.e., I write out a restart file (without using delete_atoms in the simulation) and read it using read_restart which again works fine.
I do not know why I get an error "Unexpected… " when I try to read the data file using the read_ data command when the data file is outputted from a simulation which uses a delete_atoms command ?
I am using 15 aug 2015 version, atom style full.
Any suggestions would be helpful
Arun
