I encountered a problem with the neighborlist for computerdf. I got a following array of firstneigh[90] (The neighbor list of local atom with id 90):
{93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 107, 108,
82, 83, 84, 85, 86, 87, 89, 90, 93, 94, 95, 96, 97, 98, 99, 100, 101, 102, 103, 104, 105, 107, 108,
106, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 129, 134, 135, 136, 138, 139, 143, …}
Obviously, it can be found the second row shouldn’t be here. After debugging into Neighbor::half_bin_newton, which is called by build_one in to build neighborlist, I found the binhead of atom 90 was incorrect. It should be 282 but the one gotten by function coord2bin in line 380 of neigh_half_bin.cpp is 281. When the loop over all atoms in other bins in stencil is invoked and k=0, the first bin becomes 281+stencil[0] = 282, which is the bin containing the atom 90.
This problem doesn’t always happen. My input only has a fix_npt which changes the volume of simulation box. I’m curious if it is related to the setting of neigh_modify.
The following is the minimal input file. fix polarization is a post_force style fix developed by me which adds forces due to polarization to the atoms. It works with the modified LJ pair coefficient to model Dang and Chang’s polarized water model. It requires a full neighbor list by the following code:
int irequest = neighbor->request(this,instance_me);
neighbor->requests[irequest]->half = 0;
neighbor->requests[irequest]->full = 1;
neighbor->requests[irequest]->pair = 0;
neighbor->requests[irequest]->fix = 1;
Other influence of the code is to add additional force and virial to the system. Energy is added by fix_modify.
Hope someone could give me some advice in order to further debug the problem. Thanks in advance.
Input file:
