Dear Steve,
I’m sorry to bother you again. There is still a small problem with my calculation. I find if I turn “check” to “no” for neighbor_modify. The calculation is correct. Otherwise, no matter how I increase binsize, the rdf will be like the following. There are some atoms in the first bin of rdf.
500000 1000
1 0.00475 54332.4 0.00618672
2 0.01425 0 0.00618672
3 0.02375 0 0.00618672
4 0.03325 0 0.00618672
5 0.04275 0 0.00618672
6 0.05225 0 0.00618672
7 0.06175 0 0.00618672
8 0.07125 0 0.00618672
9 0.08075 0 0.00618672
10 0.09025 0 0.00618672
After debugging, I find a possible explanation. There might be some atoms (e.g. K atom) which don’t move larger than half of neighbor skin but move out of the bin since last-reneighboring.(bin is used in neighbor list construction, assume K atom moves from original I bin to J bin. I and J are heads of binlist which are gotten by coor2bin function.) Thus the neighborlist is not rebuilt. When rdf is calculated, a neighborlist is built for rdf by build_one method. However, it uses a wrong bin structure. K atom is still stored in the bin list leaded by binhead[I] but acctually it is not in that bin. If half_bin_newton method is called to construct the neighborlist, when code runs to line 380, the bin number gotten by coor2bin is J but not I. Then when the code runs into the following loop over bins, it might loop into I bin which stores K atom. Thus K atom itself appears in its neighborlist, which results abnormal value for first bin of RDF.
I’m not pretty sure if my explanation is correct. Could you please give me some advice on calibrating the input file? I don’t think check no is a smart way to deal with it. Thank you!
Han
