I have a question regarding data for DOS from MP. I found out that MP did not give back the correct DOS for some materials, for example, LiAg_mp-2426 (see the figure I attached here). DOS for this compound is not available on webpage of MP, however, I found the same one in Aflowlib
and this DOS curve is much smoother and makes sense. I think the DOS in MP was calculated from symmetry band structure instead of uniform one. I used the following query code
from pymatgen.ext.matproj import MPRester rester = MPRester(“my_key”) # mp_id = “mp-2426” dos = rester.get_dos_by_material_id(mp_id)
Dear @anhhv
Thank you for your question!
I checked our data and the DOS you showed in the figure was calculated by the uniform method with a k-point of 19x19x19 by VASP 5.4.4 (the calculation details page for these tasks will be available soon).
It appears that AFlow has a very similar DOS (see attached) in the static plot. In their interactive plot, if you scroll down 1-2 eV you will see the spike around -6 eV, just as the DOS from MP API. Please do notice there are differences in how the calculation was run (e.g. VASP version, k-points etc.)
@anhhv please try to avoid posting your API key on a public forum. Thanks! Also, note that you’re using a legacy API key which will tell the pymatgen MPRester to connect to our legacy API serving an older version of our data. Our new website at materialsproject.org serves the latest data from our new API (api.materialsproject.org).
dos = rester.get_dos_by_material_id("mp-149")
MPRestError Traceback (most recent call last)
<ipython-input-34-90ab3dc0fd0f> in <module>
----> 1 dos = rester.get_dos_by_material_id("mp-149")
~/anaconda3/lib/python3.7/site-packages/mp_api/client.py in get_dos_by_material_id(self, material_id)
811 """
812 return self.electronic_structure_dos.get_dos_from_material_id( # type: ignore
--> 813 material_id=material_id
814 )
815
~/anaconda3/lib/python3.7/site-packages/mp_api/routes/electronic_structure/client.py in get_dos_from_material_id(self, material_id)
386 else:
387 raise MPRestError(
--> 388 "No density of states data found for {}".format(material_id)
389 )
390
MPRestError: No density of states data found for mp-149
I think there’s still problem with DOS for some metals, e. g., mp-15177. The DOS is not smooth in those examples, that raises a question of k-mesh. In addition, the energy step for DOS is very rough, around 0.1 eV.
