I would like to create bonds between different molecules to model some chemical process. I chose the set of commands "create_bonds single bond" (angle/dihedrals) because it allows me to precisely select atoms. I’m working with LAMMPS 11 Aug 2017 on Debian 4.9.65-3 (2017-12-03) x86_64.
I just created a simple test case to (hopefully) clearly explain the situation (input files are attached). The simulation box contains 2 chains with four particles each. I want to connect particles 2 and 6. I use a single FF type for each kind of interaction.
The relevant part of my input file (in.system) is
# 1---2---3---4
# 5---6---7---8
lmp.tar.gz (1.23 KB)
