Hello people,
The issue of wrong potential energies written to dump files with eam/alloy/cuda has gone from being just my personal problem to a suspected bug. Another cuda user on the list here, James Almeida, ran a test for me and got the same errors: trajectories of atoms are all calculated exactly the same as on cpus, but the potential energies of individual atoms written in the dump file are ridiculous, around -5000 eV.
If anyone else wants to look at it to confirm or undo the idea that there might be a bug, the files are attached.
The run is a small, simple one, create a block of W crystall of 6 million atoms, anneal that 200 steps. It writes dump files (given that it's 6M atoms, they get a bit large). These all seem fine, except the column with potential energy for each atom when calculated with cuda. With cpus, these are well behaved, potential energies after 200 steps around -8 eV, as they should be:
ITEM: TIMESTEP
200
ITEM: NUMBER OF ATOMS
6000000
ITEM: BOX BOUNDS pp pp pp
0 317
0 951
0 317
ITEM: ATOMS id type x y z vx vy vz fx fy fz c_ke c_pe
1 1 0.0806297 950.941 316.871 -2.19527 1.22234 -0.983909 -1.58293 2.42537 1.69776 0.0693686 -8.67786
2 1 1.42518 1.62101 1.52561 3.59783 1.72984 2.31545 1.40752 0.732235 -0.471684 0.202903 -8.77869
3 1 2.96678 0.0975968 316.899 1.51189 -1.5602 -2.52895 0.330369 0.151668 0.0605063 0.105897 -8.72994
4 1 4.50532 1.57068 1.53133 1.81658 -1.07678 -2.41491 -0.264497 3.36835 1.53948 0.0980426 -8.68915
5 1 5.9894 0.206289 316.961 -3.95444 0.946948 6.71987 3.20465 -1.30805 -1.60915 0.587719 -8.67464
With cuda, the potential energies after 200 steps can be ~-5000 eV for some atoms, which is orders of magnitude wrong:
ITEM: TIMESTEP
200
6000000
0 317
0 951
0 317
1 1 0.0806297 950.941 316.871 -2.19527 1.22234 -0.983909 -1.58293 2.42537 1.69776 0.0693686 -6.40983
2 1 1.42518 1.62101 1.52561 3.59783 1.72984 2.31545 1.40752 0.732235 -0.471684 0.202903 -5389.8
3 1 2.96678 0.0975968 316.899 1.51189 -1.5602 -2.52895 0.330369 0.151668 0.0605063 0.105897 -5391.57
4 1 4.50532 1.57068 1.53133 1.81658 -1.07678 -2.41491 -0.264497 3.36835 1.53948 0.0980426 -5414.76
5 1 5.9894 0.206289 316.961 -3.95444 0.946948 6.71987 3.20465 -1.30805 -1.60915 0.587719 -6.73543
In the thermo file, the potential energy is written correctly. And the atom trajectories over 200 steps are perfectly similar. So it seems just a pesky little problem in how the potential energy in dump files is reported. But a problem that James Almeide also got with his cuda executable.
greets,
Peter
files.tar (770 KB)
