Wrong temperature and pressure output because of wrong DOF - ellipsoidal particles
Dear Lammps experts,
I have a question regarding to the DOF of ellipsoid and simulations relating to this. The lammps version I am using is from 16Feb16
So I am trying to do a test simulation to equilibrate ellipsoidal particles at 300K and 1atm. I tried to use a soft potential to avoid overlapping before equilibrating the system in npt. My ellipsoids are 3D particles with 3 different diameters.
As I understand from the Lammps documentations, fix nvt/asphere and fix npt/asphere allow thermostat to be applied to both translational and rotational motion, so as long as I use this for my system (regarding to the fact that my ellipsoids should have 6 dof) I don’t have to use any fix_modify or compute_modify to adjust the DOF.
However, when I didn’t adjust the DOF, the temperature output was doubled (~600K). Then when I tried to subtract 3 DOF from each particle the temperature was correct. Below this message is the script with modified DOF (by adding compute_modify to modify the temp in the fixes).
I do not understand why subtracting DOF helps correcting the temperature. Any idea for this?
I would appreciate any help for this problem.
#Input file for simulation with modified DOF
#----------Initialisation----------
clear
units real
atom_style ellipsoid
#----------Create atoms----------
lattice sc 16
region lower block 0 32 0 32 5 14
create_box 1 lower
create_atoms 1 region lower
#---------Atom Settings-----------
set type 1 mass 1021.59
set type 1 shape 32.9 15.9 3.5
set group all quat/random 18238
compute q all property/atom quatw quati quatj quatk
compute shape all property/atom shapex shapey shapez
dump 1 all custom 10 dump.soft.all &
id type x y z c_q[1] c_q[2] c_q[3] c_q[4] &
c_shape[1] c_shape[2] c_shape[3]
######################---------Soft potential to prevent ovelapping---------
pair_style soft 33.0
pair_coeff 1 1 0.0 5.4
group spheroid type 1
variable dof equal count(spheroid)*3
velocity all create 300 87287 loop geom
variable prefactor equal ramp(0,100)
fix 1 all nvt/asphere temp 300 300 50
fix 2 all adapt 1 pair soft a * * v_prefactor
compute_modify 1_temp extra ${dof} #this gives T=300, without it T=600
timestep 0.5
thermo 100
thermo_style custom step pe etotal vol press temp
write_restart restart.soft
run 500000
########################----------Real Force Fields ----------
pair_style gayberne 1.0 1.0 1.0 16.0
pair_coeff 1 1 0.1 3.5 2 2 10 0 0 0
neighbor 33.0 bin
neigh_modify every 5 delay 0 check yes
################------------- Run NPT ----------------------------
reset_timestep 0
thermo_style custom step epair etotal press vol temp density
thermo 100
timestep 0.1
#----------Visualisation----------
uncompute q
uncompute shape
undump 1
dump 1 all custom 100 dump.equilibrium.ellipsoid &
dump trj all atom 100 dump.equilibrium.lammpstrj
unfix 1
unfix 2
fix 1 all npt/asphere temp 300 300 10 iso 1.0 1.0 100
run 100000
fact that my ellipsoids should have 6 dof) I don't have to use any
However, when I didn't adjust the DOF, the temperature output was doubled
Any idea for this?
​subtracting the DOFs does *not* correct the temperature. you are computing
the temperature incorrectly.
the thermo keyword "temp" uses "compute temp"​ to compute the temperature,
but that is not correct for aspherical particles as it treats them as point
particles.
​instead you should use "compute temp/asphere" and then "thermo_modify
temp".​
​axel.​
