Dear Lammps users,
I am trying to locate the atom with the highest z coordinate. I would like to know its position (x,y,z)
So far i am able to get the z coordinate of this atom, via the commands
compute zmax all reduce max z
variable zmax equal c_zmax
Is there a way to get the other two components (x,y) of this particular atom? Is there an alternative approach?
I am running LAMMPS (25 Feb 2016-ICMS)
Regards,
Sebastián
You can use the “replace” option of compute reduce to do that.
Dear Lammps users,
compute reduce has a "replace" option, where you can pick array elements
from other per-atom data based on the reduction of another.
for example, the following input:
compute c1 all property/atom id
compute c2 all reduce max x y z c_c1 replace 1 3 replace 2 3 replace 4
3
thermo_style custom step c_c2[1] c_c2[2] c_c2[3] c_c2[4]
will output, x, y, and z coordinate as well as the atom id of the atom
with the largest z value.
Great. That is exactly what i needed. Thanks
