Thx Axel,
I have run program for ZrO2 and i want to run program for doped ZrO2 (YSZ). I do not know how add Y to my program. Should I use fraction for Y and Zr and add vacancy of Oxygen?
MD Calculation of doped-ZrO2
atom_style charge
variable a0 equal 5
lattice custom ${a0} a1 1 0 0 a2 0 1 0 a3 0 0 1 basis 0 0 0 basis 0 0.5 0.5 basis 0.5 0 0.5 basis 0.5 0.5 0 basis 0 0 0 basis 0 0.5 0.5 basis 0.5 0 0.5 basis 0.5 0.5 0 basis 0.25 0.25 0.25 basis 0.75 0.75 0.75 basis 0.75 0.75 0.25 basis 0.25 0.25 0.75 basis 0.75 0.25 0.75 basis 0.25 0.75 0.25 basis 0.25 0.75 0.75 basis 0.75 0.25 0.25
region box block 0 4 0 4 0 4
create_box 3 box
create_atoms 1 box basis 1 1 basis 2 1 basis 3 1 basis 4 1 basis 5 2 basis 6 2 basis 7 2 basis 8 2 basis 9 3 basis 10 3 basis 11 3 basis 12 3 basis 13 3 basis 14 3 basis 15 3 basis 16 3
Create groups
group Zr type 1 #A for cations
group Y type 2 #B for cations
group O type 3 #C for anions
set group 1 charge 2.4
set group 2 charge 2.4
set group 3 charge -1.2
set group 1 type/fraction 1 0.8 2150
set group 2 type/fraction 2 0.2 1353
set group 3 type/fraction 3 0.9 4652
Set masses
variable 1 equal 91.224# Zr
variable 2 equal 88.915 # Y
variable 3 equal 15.999 # O
variable V equal vol
variable dt equal 0.0015
variable T equal 200
variable P equal 0.0
variable kB equal 8.6173423e-5 # [eV/K] Boltzman constant
variable eV2J equal 1.60217646e-19
variable A2m equal 1.0e-10
variable ps2s equal 1.0e-12
variable convert equal {eV2J}/{A2m}/${ps2s}
variable CL equal 10000 # correlation length
variable SI equal 1 # sample interval
variable DI equal {CL}*{SI} # dump interval
setup problem
velocity all create $T 27281 units box
pair_style buck/coul/long 10.0 10
pair_coeff 1 3 1986.8 0.3511 20.40
pair_coeff 3 3 22746.3 0.1490 45.83
pair_coeff 1 1 0.0 1.0 0.0
pair_coeff 2 3 1885.75 0.3399 20.34
pair_coeff 2 2 0.0 1.0 0.0
pair_coeff 1 2 0.0 1.0 0.0
kspace_style ewald 1.0e-4
equilibrization and thermalization
fix NPT all npt temp $T $T 0.15 iso $P $P 1.5
run 2000000
thermal conductivity calculation
unfix NPT
reset_timestep 0
compute myKE all ke/atom
compute myPE all pe/atom
compute myStress all stress/atom NULL virial
compute flux all heat/flux myKE myPE myStress
variable Jx equal c_flux[1]/vol
variable Jy equal c_flux[2]/vol
variable Jz equal c_flux[3]/vol
variable scale equal 1/${kB}/$T/$T/V*{SI}{dt}
variable k11 equal trap(f_JJ[3])*{scale}{convert}
variable k22 equal trap(f_JJ[4])*{scale}{convert}
variable k33 equal trap(f_JJ[5])*{scale}${convert}
run 2000000
variable k equal (v_k11+v_k22+v_k33)/3.0
variable ndens equal count(all)/vol
print “average thermal conductivity: $k [W/mK] @ T K, {ndens} /A^3”
Thanks Axel
I want to run this program and use write_data to create a read data file.
why read a data file, if you can create the system right away?
Also I have used:
atom_style charge
that script is just one part of program.
it is extremely irritating and frustrating when people post incomplete and non-functioning input script code. you are just inviting people to give you incorrect advice.
I do not understand how to make fraction?
a fraction of what? where and how and with what command, and why do you want/need to do this?
Is it need to put vacancy?
how should anybody be able to answer this question?
in general, the quality and usefulness of responses to your question crucially depends on the quality and clarity of the information you provide and how well formulated your questions are. you are so far doing a bad job in that regard and thus there is only very little help that can be given.
