Subject: Looking for a ReaxFF parameter file for Zn/Cl/C/H/O systems (ZnCl₂–lactic acid DES)
I am preparing LAMMPS ReaxFF simulations to investigate the interactions between a ZnCl₂-based deep eutectic solvent (DES) and lignin. The DES consists of ZnCl₂ and lactic acid, and my objective is to study the reactive interactions between the solvent and lignin during biomass pretreatment.
The reactive elements required in the force field are:
Zn
Cl
C
H
O
I searched the available ReaxFF parameter files distributed with LAMMPS and the SCM ReaxFF database. While I found parameterizations for systems such as CHOZn, ZnOH, CHON, and CHONSMgPNaCuCl, I could not find a single validated ReaxFF parameter file that simultaneously includes Zn, Cl, C, H, and O for organic systems.
Could anyone advise whether there is a publicly available LAMMPS-compatible ReaxFF parameter file suitable for Zn/Cl/C/H/O chemistry? In particular, I am interested in parameterizations that have been used for:
ZnCl₂-based deep eutectic solvents
ZnCl₂ interacting with oxygenated organic molecules
ZnCl₂–biomass or ZnCl₂–lignin systems
Molten ZnCl₂ or ZnCl₂-containing reactive simulations
I understand that simply matching the element set is insufficient and that any candidate force field must be validated against the chemistry of interest. Before production simulations, I plan to validate the force field by examining Zn–Cl coordination, Zn–O interactions with lactic acid, and available structural or thermodynamic data.
If anyone knows of a published parameter file, repository, or research group that has developed a Zn–Cl–C–H–O ReaxFF parameterization, I would greatly appreciate your guidance.
Thank you for your time and assistance.
