0 temperature with fix cha/reg
Hi!
I am trying to simulate a charge regulation of a fiber. I am fixing the fiber in the cell space using fix setforce and run charge regulation with very low initial charge. Everything works well except the temperature of the system is 0. I checked the trajectory, the ions are actually stationary. I tried both tempfixid and temp options but still get 0 temperature. Could you help with this?
Another funny thing is even though I used fix setforce on the fiber, it still slowly moving in the trajectory. It would be wonderful if you can help with this as well!
Thanks!
Yang
init.data (289.6 KB)
in.chreg_nanotube (5.9 KB)
