I’m trying to enable the jpeg image writing command as described at
https://docs.lammps.org/Build_settings.html
in section 3.5.4.
What I can’t figure out is where to insert those additional Make lines.
The Makefile in Obj_serial (I’m using “make serial”) is created by the make process somewhere so modifying it to match the instructions doesn’t work because it just gets rewritten.
Adding the lines to the main Makefile also doesn’t work.
The information you are looking for is presented earlier in the documentation: 3.2. Build LAMMPS with make — LAMMPS documentation
Bottom line:
- copy
src/MAKE/Makefile.serial
to src/MAKE/MINE/Makefile.serial
- edit
to your liking. Use the embedded comments as guide.
- run
make serial
Or use the CMake build procedure where support for image file formats and multiple other things is auto-detected and thus setting explicit flags rarely required.
