Hey @leila_karami, the easiest way is using our python client to download documents and filter based on whether they come from an amorphous calculation. This provenance information isn’t stored for every material.
There are many caveats when trying to represent an amorphous material as a small ordered cell. The resultant structure could be phase separated, or not accurately reflect the bulk amorphous material.
With those caveats, the following code snippet uses our client to retrieve all materials that have an SiO2 formula unit, then retrieves their provenance to see if any were tagged as derived from an “amorphous” structure.
The final material IDs, which may be representations of amorphous SiO2, are in amorphous_si_o2_mpids
I found 7 possibly amorphous SiO2 entries in MP
["mp-1244945", "mp-1244965", "mp-1244968", "mp-1245026", "mp-640917", "mp-6930", "mp-6945"]
from pymatgen.core import Composition
target_composition = Composition({"Si": 1, "O": 2})
with MPRester() as mpr:
si_o_mpids = [
doc.material_id
for doc in mpr.materials.search(chemsys="Si-O", fields = ["material_id","composition_reduced"])
if doc.composition_reduced == target_composition
si_o_prov = mpr.materials.provenance.search(material_ids=si_o_mpids)
amorphous_si_o2_mpids = [doc.material_id.string for doc in si_o_prov if any("amorphous" in tag.lower() for tag in doc.tags)]
There’s also a database of non-crystalline materials which was recently published via MPContribs.
Using similar code to extract entries:
contribs_data = mpr.contribs.query_contributions({"project": "amorphous_diffusivity"},paginate=True)
contribs_si_o2_entries = [entry for entry in contribs_data["data"] if Composition(entry["formula"]).reduced_composition == target_composition]
I found only one possibly amorphous SiO2 entry
