Dear developers,
I want to calculate thermal conductivity based on the renormalized IFCs, so I wonder if we can construct a 4th order effective harmonic model from MD snapshots using Hiphive?
Kind regards,
Junwei
What do you mean by 4th order effective harmonic model?
Harmonic models are by definition only second order.
Sorry, I didn’t make my question clear. I got the renormalized 2nd and 3rd order IFCs with the script below, so can we get the renormalized 4th order IFCs in Hiphive?
import os
import numpy as np
import warnings
from ase.io import read
from hiphive import ClusterSpace, StructureContainer, ForceConstantPotential
from trainstation import Optimizerwarnings.filterwarnings(“ignore”, category=DeprecationWarning)
temperatures = [1500, 1600, 1700, 1800]
cutoffs = [8.0, 5.0]for T in temperatures:
structures = read(‘md_runs/snapshots_T{:}.xyz’.format(T), index=‘:’)cs = ClusterSpace(structures[0], cutoffs) sc = StructureContainer(cs) for s in structures: sc.add_structure(s) # set up inds2 = cs.get_parameter_indices(order=2) inds3 = cs.get_parameter_indices(order=3) assert cs.n_dofs == len(inds2) + len(inds3) A, y = sc.get_fit_data() # train fc2 opt = Optimizer((A[:, inds2], y), train_size=1.0) opt.train() print(opt) params_2 = opt.parameters y2 = y - np.dot(A[:, inds2], opt.parameters) # train fc3 opt = Optimizer((A[:, inds3], y2), train_size=1.0) opt.train() print(opt) params_3 = opt.parameters # combine parameters from both fits params = np.zeros(cs.n_dofs) params[inds2] = params_2 params[inds3] = params_3 # make fcp fcp = ForceConstantPotential(cs, params) # save fcp file output_directory = 'fcps' if not os.path.exists(output_directory): os.makedirs(output_directory) fcp.write(os.path.join(output_directory, '3rd_ehm_T{}.fcp'.format(T)))
Yes thats possible, you just need to make the ClusterSpace bigger to contain fourth-order terms, see documention
and if you’re doing sequential fitting then you would need to add similar code snippet for the fourth-order parameters as you already have in your script.
Thank you so much.
