Hi Steve,
thank you very much for your reply! My input script is as follows:
atom_style molecular
read_data medium_10_layer_updated.lammps05
dump xyz_graphene all xyz 10000 graphene_atom_medium_10_layer_from_npt.xyz graphene_atom_10_layer.out id mol x y z
timestep .0005 #picoseconds
velocity all create 300 12390
group layer1 type 1
group layer2 type 2
group layer3 type 3
group layer4 type 4
group layer5 type 5
group layer6 type 6
group layer7 type 7
group layer8 type 8
group layer9 type 9
group layer10 type 10
group block1 type <> 1 5
group block2 type <> 6 10
group center1 type <> 4 5
group center2 type <> 6 7
group center11 type <> 6 7
group center12 type <> 8 9
group center21 type <> 7 8
group center22 type 9 10
pair_style hybrid lj/smooth/linear 7.13176 tersoff
pair_coeff * * tersoff SiC.tersoff C C C C C C C C C C
pair_coeff 1 2*10 lj/smooth/linear .003 3.4
pair_coeff 2 3*10 lj/smooth/linear .003 3.4
pair_coeff 3 4*10 lj/smooth/linear .003 3.4
pair_coeff 4 5*10 lj/smooth/linear .003 3.4
pair_coeff 5 6*10 lj/smooth/linear .003 3.4
pair_coeff 6 7*10 lj/smooth/linear .003 3.4
pair_coeff 7 8*10 lj/smooth/linear .003 3.4
pair_coeff 8 9*10 lj/smooth/linear .003 3.4
pair_coeff 9 10 lj/smooth/linear .003 3.4
neighbor 2.0 bin
neigh_modify delay 0 every 20 check no
fix 1 all npt temp 300.0 300.0 0.1 x 1.0 1.0 0.2 y 1.0 1.0 0.2 z 1.0 1.0 0.2 drag 0.2
#compute morsePE all pair lj/smooth/linear
compute PEblock block1 group/group block2
compute PEcenter0 layer5 group/group layer6
compute PEcenter center1 group/group center2
compute PEcenter1 center11 group/group center12
compute PEcenter2 center21 group/group center22
compute PEbound layer1 group/group layer10
fix calcPELJ all ave/time 1 500 500 c_PEblock c_PEcenter0 c_PEcenter c_PEcenter1 c_PEcenter2 c_PEbound file PELJ.profile
thermo_style custom step temp pe ke etotal c_PEblock c_PEcenter0 c_PEcenter c_PEcenter1 c_PEcenter2 c_PEbound
thermo 100
run 10000
I monitored the interaction energy between several pairs of groups as defined in the script.
The thermo output of 1 processor run is:
Memory usage per processor = 13.2838 Mbytes
Step Temp PotEng KinEng TotEng PEblock PEcenter0 PEcenter PEcenter1 PEcenter2 PEbound
0 300 -20591.202 108.53974 -20482.662 -35.982298 -12.360447 -12.367833 -8.6242827 -12.021959 -17.659791
100 160.46224 -20753.834 58.055103 -20695.778 -31.496998 -10.822025 -10.827605 -7.8479427 -10.569837 -17.312917
200 160.50746 -20747.084 58.071461 -20689.012 -29.739504 -10.760975 -10.764245 -7.8430489 -10.633853 -17.255462
300 174.16506 -20745.477 63.01277 -20682.464 -28.580609 -10.838329 -10.840682 -7.859317 -10.689181 -16.758839
400 187.0805 -20743.598 67.685566 -20675.912 -28.368535 -11.008486 -11.010793 -7.8285857 -10.550734 -16.8122
500 188.39422 -20737.624 68.160866 -20669.463 -28.789981 -11.086765 -11.089402 -7.8313876 -10.562458 -17.229449
600 184.64988 -20729.652 66.806171 -20662.846 -29.319951 -11.099756 -11.103119 -7.736693 -10.614819 -17.628407
700 200.88337 -20728.793 72.679431 -20656.113 -29.730889 -11.143994 -11.149758 -7.6999079 -10.516923 -17.810558
800 202.53252 -20722.62 73.276093 -20649.344 -30.041089 -11.157048 -11.168049 -7.7919514 -10.260461 -17.868569
The thermo output for the 12 processors run is:
Memory usage per processor = 6.98042 Mbytes
0 300 -20589.823 108.53974 -20481.283 -32.238749 -8.6168978 -8.6242844 -8.6242827 -8.6242862 -17.659791
100 160.46224 -20755.941 58.055103 -20697.886 -28.72091 -7.9964096 -8.0515182 -7.8479427 -8.1396255 -17.312917
200 160.50746 -20750.028 58.071461 -20691.957 -26.960941 -7.9386613 -7.9856815 -7.8430489 -8.2870153 -17.255462
300 174.16506 -20748.58 63.01277 -20685.567 -25.732705 -7.9508024 -7.9927783 -7.859317 -8.3968252 -16.758839
400 187.0805 -20746.495 67.685566 -20678.81 -25.42405 -8.0144726 -8.0663078 -7.8285857 -8.2129768 -16.8122
500 188.39422 -20740.175 68.160866 -20672.014 -25.724976 -7.974708 -8.0243971 -7.8313876 -8.1479309 -17.229449
600 184.64988 -20732.261 66.806171 -20665.454 -26.211196 -7.9365191 -7.9943637 -7.736693 -8.2242309 -17.628407
700 200.88337 -20731.524 72.679431 -20658.844 -26.622133 -7.9725024 -8.041003 -7.6999079 -8.108174 -17.810558
800 202.53252 -20725.618 73.276093 -20652.341 -26.911697 -7.9401552 -8.0386572 -7.7919514 -7.8839057 -17.868569
First, PEbound column is much larger than PEcenter0 column, the former specifies the interaction between boundary two layers and the latter between central two layers. Second, the two runs give different interaction energy, which can be exemplified by the difference between the PEcenter0 column in different runs.
