A cuda package error
Dear lammps users,
An error occurred when using cuda package. I use the sw potential to calculate the thermal conductivity.
Do you have any suggestions? Thank you in advance!
Here is the error and input.
WARNING: # CUDA: You asked for a Verlet integration using Cuda, but several fixes have not yet been ported to Cuda.
This can cause a severe speed penalty due to frequent data synchronization between host and GPU. (verlet_cuda.cpp:632)
Cuda error: Cuda_CommCuda_PackReverse_Self: Kernel execution failed in file ‘comm_cuda.cu’ in line 483 : unknown error.
variable T equal 70
variable V equal vol
variable dt equal 0.001
variable p equal 20 # correlation length
variable s equal 10 # sample interval
variable d equal $p*$s # dump interval
convert from LAMMPS real units to SI
variable kB equal 1.3806504e-23 # [J/K] Boltzmann
variable eV2J equal 1.60219e-19
variable A2m equal 1.0e-10
variable ps2s equal 1.0e-12
variable convert equal {eV2J}*{eV2J}/{ps2s}/{A2m}
setup problem
lattice diamond 5.43
region simbox block 0 6 0 6 0 6 units lattice
create_box 1 simbox
create_atoms 1 box
mass 1 28.0855
pair_style sw
pair_coeff * * Si.sw Si
neighbor 1.0 bin
neigh_modify delay 0 every 200 check no
timestep ${dt}
thermo $d
equilibration and thermalization
velocity all create $T 102486 mom yes rot yes dist gaussian
fix NVT all nvt temp $T $T 10 drag 0.2
run 200
thermal conductivity calculation, switch to NVE if desired
unfix NVT
fix NVE all nve
reset_timestep 0
compute myKE all ke/atom
compute myPE all pe/atom
compute myStress all stress/atom virial
compute flux all heat/flux myKE myPE myStress
variable Jx equal c_flux[1]/vol
variable Jy equal c_flux[2]/vol
variable Jz equal c_flux[3]/vol
fix JJ all ave/correlate $s $p $d &
c_flux[1] c_flux[2] c_flux[3] type auto file J0Jt.dat ave running
variable scale equal {convert}/{kB}/$T/$T/$V*s*{dt}
variable k11 equal trap(f_JJ[3])*${scale}
variable k22 equal trap(f_JJ[4])*${scale}
variable k33 equal trap(f_JJ[5])*${scale}
thermo_style custom step temp v_Jx v_Jy v_Jz v_k11 v_k22 v_k33
run 400
variable k equal (v_k11+v_k22+v_k33)/3.0
variable ndens equal count(all)/vol
print “average conductivity: $k[W/mK] @ T K, {ndens} /A^3”
Best Regards,
Richard
I think Christian said he was looking into this ...
