From the official guide, the explanation about setting “pair_coeff” command line in granular package,
For granular styles there are no additional coefficients to set for each pair of atom types via the pair_coeff command. All settings are global and are made via the pair_style command. However you must still use thepair_coeff for all pairs of granular atom types. For example the command “”"""
It says that the coefficient of interaction model has already been set up in the “pair_style” command line globally. However, in my simulation, there will be two kind of matters, or saying two types of particles, on my opinion, I should set up at least three groups of parameters for the interaction model, right? Why granular package is so unique that define parameters in pair_style command line not the pair_coeff?
From the official guide, the explanation about setting "pair_coeff" command
pair_coeff * *
the "pair_style" command line globally. However, in my simulation, there
because that is the model that is being implemented. if you want more
sophisticated granular models, you have to look at the LIGGGHTS
package, which is a fork of LAMMPS with extensions specifically aimed
at granular media.
pair_coeff * *
If you only want different sizes of particles you can use gran/hertz/history. Otherwise do what Axel said and look at LIGGGHTS.
