I am trying to understand how the log append can be useful in restarting the calculation from a restart file.
The following situation happens.
I start an MD simulation for 15 hours, but the simulation requires 18 hours of simulating time to finish, so because of the wrong estimation of the time to finish, the log file now contains a line at an arbitrary timestep, and this line is incomplete.
Here the last 2 lines for comparison:
991000 600.16942 -204030.34 -202013.39 -1.7232312 360813.26 677.45993 25.955502 20.519626 90 90 90 182.67295 -1117.7095 929.86681 -817.12833 -31.053616 11.832623 26000
991500 595.69589 -204044.91 -202042.99 -1244.8861 360857.44 677.54289 25.955502 20.519626 90 90 90 -985.72463 -1758.3697 -990.56402 -1212.0344 212.33054 -126.53518
Notice that the last column is empty on the last line, but it shouldn’t be.
Trying to solve this, one should restart the calculation from the last restart file that was written. This will be at the timestep 990,000, and to use this, probably the option log append seems like the right option here. However, using
log append simulation.log
only appends and doesn’t remove the timesteps between 990,000 and the last written one at 991,500. This leaves the log file ugly and impossible to parse correctly without deleting those lines.
I want to ask, if there is a method to use the restart file to start the simulation at a certain timestep and then have the log file being seamlessly joined between the original one and the one created after restarting the simulation without the extra lines in the middle, i.e., steps [990,000-991,500].
My idea of a perfect log in this case is a log file deleting all the lines from the original simulation in the interval [990,000-991,500] and continuing with the restart file from 990,000-END. I could almost see Axel writing the comment that my idea is wrong
, but I wanted to share my idea, since maybe is out there.
Thanks for your help.
Using LAMMPS versions Aug23
&& Jan24
Ubuntu 22.04 system
Simulating between 100 Atoms and 26000 atoms using MD fix npt, nvt, time/ave
