I get two diffrent results while using “compute reduce ave and sum” in computing addforce .i think it is a bug in lammps. see my two code:
CODE 1
units lj
fix 6 all addforce 7 0 0
compute avefx all reduce ave fx
compute sumfx all reduce sum fx
thermo_style …c_avefx c_sumfx
---------------------------------------------END of code 1
The result was: avefx=7 and sumfx=7
CODE 2
units real
fix 6 all addforce 0.5 0 0
-------------------------------------------END of code 2
The result was: avefx=0.5 and sumfx=50 NOTE that the total number of atoms in the group “all” was 100.
So, i think it is a bug in LAMMPS. am i wrong?
mahdi sahebi
I get two diffrent results while using "compute reduce ave and sum" in
unlikely.
CODE 1
units lj
thermo_style ....c_avefx c_sumfx
CODE 2
units real
in the group "all" was 100.
you are wrong.
the difference is that in case 1 you implicitly (due to using reduced
units) have
thermo_modify norm yes
and in case 2 you implicitly have
thermo_modify norm no
if you change that, you'll see that the compute reduce sum output will change.
