I wanted to add a modified version of the fene_expand bond where the bond and the WCA are shifted by different constants:
E = -\frac{K R_0^2}{2} \ln \left[ 1 - \left( \frac{r - \Delta_1}{R_0} \right)^2 \right] + U_{LJ} \left( \frac{\sigma}{r - \Delta_2} \right)
I took the fene_expand code and created a modified fene_expand2. Results are on my github.
I am compiling (on a cluster) with
#!/bin/bash
BUILD_NAME=dev_my
cd lammps
mkdir build_${BUILD_NAME}
cd build_${BUILD_NAME}
module purge
module load intel/19.1.1.217
module load intel-mpi/intel/2019.7
cmake3 -D CMAKE_INSTALL_PREFIX=$HOME/.local \
-D LAMMPS_MACHINE=della_${BUILD_NAME} \
-D ENABLE_TESTING=no \
-D BUILD_MPI=no \
-D BUILD_OMP=yes \
-D CMAKE_BUILD_TYPE=Release \
-D CMAKE_CXX_COMPILER=icpc \
-D CMAKE_CXX_FLAGS_RELEASE="-Ofast -xHost -qopenmp -restrict -DNDEBUG" \
-D PKG_MOLECULE=yes \
-D PKG_RIGID=yes \
-D PKG_KSPACE=yes -D FFT=MKL -D FFT_SINGLE=yes \
-D PKG_INTEL=yes \
-D PKG_EXTRA-PAIR=yes \
-D INTEL_ARCH=cpu -D INTEL_LRT_MODE=threads ../cmake
make -j 10
make install
and I am getting
In file included from /home/polyachenkoya/software/lammps/build_dev_my/styles/style_bond.h(4),
from /home/polyachenkoya/software/lammps/src/force.cpp(101):
/home/yp1065/software/lammps/src/MOLECULE/bond_fene_expand2.h(16): error: identifier "BondFENEExpand2" is undefined
BondStyle(fene/expand2, BondFENEExpand2);
I tried to find if there are any extra places where fene_expand is mentioned by running
grep -nHIrF -- bond_fene_expand
and
grep -nHIrF -- BondFENEExpand
in my root lammps directory and the src
parts (I did not implement docs and other stuff) of both outputs look identical for bond_fene_expand / bond_fene_expand2
and BondFENEExpand / BondFENEExpand2
So I am having trouble finding how my code for bond/fene/expand2
is different from the existing bond/fene/expand
so that one compiles but not the other.
