Dear all
I'm trying to simulate the evaporation of water from nanoporous graphene. The whole system is simulated in NVT ensemble about 100,000 timesteps for equlibrium and in NPT ensemble followed about 20,000,000 timesteps for evaporation. However, the error ( Non-numeric box dimensions - simulation unstable ) occurred at about 4,000,000 timesteps. There is no abnormal temperature or pressure along the whole simulation. I supposed that the pressure of the box became higher with evaporation and finally the lammps couldn't change the box size any more. I don't know if I am right and my input is as followed. Hope and thanks for your advice!
# Initialzation
units real
atom_style full
# Force fields
pair_style lj/cut/coul/long 10 12
bond_style harmonic
angle_style harmonic
read_data watergraphene-$rnm.data
kspace_style pppm 1.0e-6
set type 2 charge 0.41
set type 3 charge -0.82
pair_coeff 1 1 0.1479999981 3.6170487995 # C
pair_coeff 2 * 0.0000000000 0.0000000000 # H
pair_coeff 3 3 0.1554164124 3.1655200879 # O
pair_coeff 1 3 0.1048294600 3.190 # C & O
group C type 1
group H type 2
group O type 3
group water union O H
bond_coeff 1 480.0000 1.4200
bond_coeff 2 540.6336 0.9600
angle_coeff 1 90.0000 120.0000
angle_coeff 2 50.0000 104.5000
angle_coeff 3 0 0
delete_bonds all angle 3 remove
# Settings
neighbor 2.0 bin
neigh_modify delay 5
velocity water create ${temp1} 123456
velocity C set 0 0 0
timestep 1
write_dump all atom dump.setup_Watergraphene_rnm\_{temp2}K.lammpstrj
# Run for equlibrium
# Fix
group none subtract water water
change_box none z final -300 400
fix mem C setforce 0 0 0
fix 1 water nvt temp \{temp1\} {temp1} 100 drag 0.2
# Output
thermo 1000
restart 5000000 restartWatergraphene_rnm\_{temp2}K.*
# Dump
dump 1 all custom 10000 dump_Watergraphene_rnm\_equil\_{temp2}K.lammpstrj type element mass x y z # 10000
# Run
run 100000
unfix 1
undump 1
# Heating & Evaporation
dump 1 all custom 100000 dump_Watergraphene_rnm\_{temp2}K.lammpstrj type element mass x y z #1000000
fix 1 water npt temp \{temp2\} {temp2} 100 x 1.0 1.0 0.2 y 1.0 1.0 0.2 z 1.0 1.0 0.2 drag 0.2
run 20000000
