Is it possible to have multiple arguments in the pre_rocket part? For example I need to run a “module switch xxxx” command and a “module load yyyy” command before the rocket_launch part, how should I write them in the pre_rocket?
I have tried this but only the last pre_rocket line “pre_rocket: ‘module load yyyy’” was created in the PBS script.
pre_rocket: ‘module switch xxxx’
Thanks.
Hi Lianshan
The default file format for my_qadapter is YAML. You can use the YAML multiline features to put a multiline command inside the pre_rocket command. You can check the YAML docs for more details, but it looks like this:
pre_rocket: |
module load python/2.7.3
module swap numpy numpy/1.8.2
Thanks.
