I use ATAT to get a 16 atom supercell (222) SQS structure. But I don’t think I got the correct result. Could please help me check which step I did wrong? Thank you very much.
The details are as follows:
I prepare rndstr.in (bcc structure with 2 atoms in unit cell, lattice constant a=3.43)
I add number 1 in the first line of sqscell.out, as follows
1
3.43 3.43 3.43
3.43 -3.43 3.43
3.43 3.43 -3.43
But accoring to the manual, the sqscell.out should be given in multiple of the coordinate system, so typically integers…did I get the correct sqscell.out??
mcsqs -n = 16 -rc
In the bestsqs.out file, I found that there are only 8 atoms (but in fact I need 16 atoms!!!), with 6 A and 2 B atoms. What’s the worse, I got the the stucture with very low symmetry, alpha=beta=90, but gamma=120!!! It is hexagonal…It is not what I want…
Could you please give me some tips??? Thank you very much…
Your step 4 is not needed. Your sqscell.in should just be the same as your supercell.in but with a 1 on top (assuming you are using version 3.07 or above).
Then run
mcsqs -rc
BTW, why not just run mcsqs -n=16 and forget about specifying your own supercell ? 16 atom is small enough so the automatic supercell generation should be quick.
Thanks a lot for your reply. I tried your method, and got three bestsqs.out structures, i.e., A_0.25B_0.75, A_0.5B_0.5, and A_0.75B_0.25.
In order to transform the bestsqs files to CIF files, I did like this:
cp bestsqs.out str.out
runstruct_vasp
Then I got POSCAR.relax and POSCAR.static, and open POSCAR.static with vesta.
I found that A_0.75B_0.25 and A_0.25B_0.75 structures are with low symmetry, alpha=gamma=90 degree, but beta is not 90 degree…
Is it correct??? I thought that the supercell should at least keep the symmetry, i.e., alpha=beta=gamma=90 degree…
btw, is there any method which could directly transform the bestsqs.out to CIF files???
According to the manual, str2cif can converts an ATAT structure file to the CIF. But how to ?
I did not find the format of stdin or stdout in the manual…
It is completely normal for a SQS to have a lower symmetry than the unit cell and for the lattice vectors to relax away from the starting high-symmetry angles.
It is also completely normal for the supercell to be quite different from the unit cell.
(Have a look at the original SQS references.)
The syntax to convert to CIF is simply
str2cif < bestsqs.out > bestsqs.cif
stdin and stdout are the usual UNIX names for standard input and standard output
(google these terms)
