It’s that when a v_name appear in the velocity command, The units option in velocity command turn into " box“ automatically? why?
It's that when a v_name appear in the velocity command, The units option in
because that is how the code is programmed. apparently until now
nobody has tried to use variables with lattice units or checked the
results.
this is a bit confusing, but it’s consistent with
the way other commands that allow for variable
inputs work - i.e. the variable values are always treated
in box units, not lattice units. Note that
variables can query the lattice spacing, so
it should be possible to define a variable to
do whatever you want.
I added a line to the doc page for the velocity
command to clarify this.
