My data file contains 3 polymer molecules of polyethylene of 200 carbon atoms each. I am very new to lammps and I have tried to minimize the molecule and it is not showing any errors. The only problem is that the molecule is not getting minimized as seen through the dcd file, i.e., the polymer molecule just comes closer and vibrates from the same position through out.
It will be great if anyone can help me with this.
My configuration file :
units real
atom_style full
read_data final.in
pair_style lj/cut/coul/cut 12.0
bond_style harmonic
angle_style harmonic
dihedral_style opls
pair_modify mix geometric tail yes
special_bonds lj/coul 0.0 0.0 0.5
pair_coeff 1 1 0.066 3.50 # CT
pair_coeff 2 2 0.03 2.50 # HC
bond_coeff 1 268.0 1.529 # CT-CT
bond_coeff 2 340.0 1.090 # CT-HC
angle_coeff 1 58.35 112.7 # CT-CT-CT
angle_coeff 2 37.5 110.7 # CT-CT-HC
angle_coeff 3 33.0 107.8 # HC-CT-HC
dihedral_coeff 1 1.740 -0.157 0.279 0.00 # CT-CT-CT-CT
dihedral_coeff 2 0.000 0.000 0.366 0.000 # CT-CT-CT-HC
dihedral_coeff 3 0.000 0.000 0.318 0.000 # HC-CT-CT-HC
velocity all create 300.0 20
fix 1 all nve
run 100
minimize 1.0e-4 1.0e-6 100 1000
write_restart min.restart
timestep 1.0
reset_timestep 0
neigh_modify every 10 delay 20 check yes
thermo 400
thermo_style multi
velocity all scale 300.0
unfix 1
fix 1 all npt temp 300 300 100 aniso 0.0 0.0 1555
fix 2 all langevin 300.0 300.0 50.0 1233
dump 1 all dcd 400 18xmixedhexane-eq.dcd
dump_modify 1 unwrap yes
run 100000
unfix 1
unfix 2
compute eng all pe/atom
compute eatoms all reduce sum c_eng
reset_timestep 0
fix 1 all nvt temp 300.0 300.0 100.0
thermo 20
thermo_style custom step pe lx ly lz press pxx pyy pzz c_eatoms
min_style cg
minimize 0.0 0.0 500000 1000000
write_restart eq.restart
write_data final1.in
My data file :
LAMMPS data file. CGCMM style. atom_style full generated by VMD/TopoTools v1.5 on Sat Dec 03 22:51:04 IST 2016
1806 atoms
1803 bonds
3600 angles
5373 dihedrals
0 impropers
2 atom types
2 bond types
3 angle types
3 dihedral types
0 improper types
-100.444485 100.150112 xlo xhi
-100.575669 100.180431 ylo yhi
-100.702575 100.205925 zlo zhi
Masses
1 12.011000 # CT
2 1.008000 # HC
Atoms
1 1 1 -0.180000 -56.376385 -0.182120 1.002175 # CT POL
2 1 1 -0.120000 -56.221386 0.276880 -0.463825 # CT POL
3 1 1 -0.120000 -55.416386 -0.709120 -1.335825 # CT POL
4 1 2 0.060000 -55.692383 1.246881 -0.532825 # HC POL
5 1 2 0.060000 -57.239384 0.429880 -0.882825 # HC POL
6 1 1 -0.120000 -53.930386 -0.692120 -0.929825 # CT POL
7 1 2 0.060000 -55.481384 -0.347120 -2.384825 # HC POL
8 1 2 0.060000 -55.844383 -1.733119 -1.289825 # HC POL
9 1 1 -0.120000 -53.011383 -1.485120 -1.866825 # CT POL
Also it will be great if you can tell me from where I can learn about md simulation for polymers in lammps.
