Hello everyone,
It may be a trivial question but I’ll really appreciate if I can get a clue regarding this issue. Is there any way to apply lammps command: “displace_atoms” for any certain atom rather than a group of atoms. For some specific reason I need to translate a single atom. What is the best way to do that?
Thanks in advance
Rezwan
Rezwan,
I think you can declare the atom you want to translate as a separate group
and use displace_atoms command on it.
Freddie.
Rezwan,
I’m new to LAMMPS. It looks like you have to define a 3D region to be a group that encompasses only the atom you want to move. Then apply displace_atom to the group containing the atom. Looks like the atom will move the specified displacement in the cell not just the defined region. I guess one could sort all the atoms around the target atom to find the closest points and construct
a rectangular box around the target atom?
Hello everyone,
It may be a trivial question but I'll really appreciate if I can get a clue
"displace_atoms" for any certain atom rather than a group of atoms. For some
do that?
a group can consist of just one atom. where is the problem?
See the group command. There are various
ways to specify a group. If you know the
ID of the single atom, that's all you need.
