hi,
I’m trying to use pair_style dipole/cut in my simulations. Lmp returns “ERROR: Pair dipole/cut requires atom attributes q, mu, torque (pair_dipole_cut.cpp:357)”. In the data files the atom attributes q,mu have been given,but I can’t find where the torque shoud be given.
How to fix this error?
Thank you.
Cun
hi,
I'm trying to use pair_style dipole/cut in my simulations. Lmp returns
"ERROR: Pair dipole/cut requires atom attributes q, mu, torque
(pair_dipole_cut.cpp:357)". In the data files the atom attributes q,mu have
been given,but I can't find where the torque shoud be given.
the error message does not result from the data file, but
indicates that you didn't choose the required atom style dipole.
hi Axel,
I have chosen atom style dipole, and write the Atoms section with these keywords “atom-ID atom-type q x y z mux muy muz”, as “read_data” manual page said.
So my question is: atom attributes q,mu have been given in the data file, but where torque should be given?
Here is my test script as following:
==== input script
atom_style dipole
boundary s s s
neighbor 2.0 bin
neigh_modify every 1 one 5000
read_data datafile
set group all charge 0.0
set group all dipole/random 98934 0.75 #0.0 0.0 0.416
velocity all create 0.0 87287 mom no
pair_style dipole/cut 10.0 10.0
pair_coeff * * 0.00284 3.4
timestep 0.001
thermo 1
run 1
==== datafile
LAMMPS data file.
2 atoms
2 atom types
-28.541000 63.623001 xlo xhi
-28.541000 28.541000 ylo yhi
-0.615000 500.421011 zlo zhi
Masses
1 12.010700 # C0
2 12.010700 # C1
Atoms
1 1 0.000000 13.541000 0.000000 0.000000 0.0 0.0 0.0 # C0
2 2 0.000000 13.467000 1.415000 0.000000 0.0 0.0 0.0 # C0
You should not get that error if you use atom_style dipole.
Try running examples/dipole/in.dipole. It works fine
on my box.
hi Axel,
keywords "atom-ID atom-type q x y z mux muy muz", as "read_data" manual page
said.
nowhere. do you need to specify forces for regular atoms??
