Hello, lammps users
I want to build bulk solvation of H2O2, before that I tried a single molecule and see if it is OK. But somehow it shows error " Shake clusters are connected ".
the data is below:
4 atoms
3 bonds
2 angles
1 dihedrals
0 impropers
2 atom types
2 bond types
1 angle types
1 dihedral types
0 improper types
-35 35 xlo xhi
-35 35 ylo yhi
-35 35 zlo zhi
Masses
1 1.008 # HGP1
2 15.9994 # OG311
Pair Coeffs # lj/charmm/coul/long
1 0.046 0.400013524445 0.046 0.400013524445 # HGP1
2 0.1921 3.14487247504 0.1921 3.14487247504 # OG311
Atoms # full
1 1 2 -0.5 1 1 0 # OG311
2 1 2 -0.5 -0.453 1 0 # OG311
3 1 1 0.5 1.111 1 -0.97 # HGP1
4 1 1 0.5 -0.564 1.001 0.97 # HGP1
Bond Coeffs # harmonic
1 545 0.96 # HGP1 OG311
2 428 1.42 # OG311 OG311
Bonds
1 2 1 2 # OG311 OG311
2 1 1 3 # HGP1 OG311
3 1 2 4 # HGP1 OG311
Angle Coeffs # charmm
1 60 101.5 0 0 # HGP1 OG311 OG311
Angles
1 1 1 2 4 # HGP1 OG311 OG311
2 1 2 1 3 # HGP1 OG311 OG311
Dihedral Coeffs # charmm
1 0.18 3 0 1 # HGP1 OG311 OG311 HGP1
Dihedrals
1 1 3 1 2 4 # HGP1 OG311 OG311 HGP1
And the fix shake command I use is this:
fix rigid_H2O2 all shake 0.0001 10 100 b 1 2
I have read the lammps documentation and lots of issue discussions about fix shake, the most likely problem is from one of the letters saying that there might be mis-connected bond between two H, but it is clear that there is only 3 bonds per molecule in my data.
after that, I try
and
fix rigid_H2O2 all shake 0.0001 10 100 b 2
and
fix rigid_H2O2 all shake 0.0001 10 100 a 1 b 1
and
fix rigid_H2O2 all shake 0.0001 10 100 a 1 b 2
and
fix rigid_H2O2 all shake 0.0001 10 100 t 1 (or t 2)
they all worked fine, however once I do combinations like
b1 t2
or
a1 t2
it just shows error “Shake clusters are connected”
and i really cannot see how they are connected
any help is appreciated, thank you
