hello,everyone,
this is Rufer.I am modeling friction about a silicon substrate and a silicon tip. the silicon substrate has three layer,fixed layer,newton layer and thermostat layer ,when I give a velocity to tip at a angle relative to X axis,I use fix langevain to control the temperature of thermostat layer .but I need to exclude the impact of velocity in x,y,and load in z,so I use compute temp/partial 0 0 0,but the temperature keeps rising.how should I deal with it, can I change the X axis along the velocity fix it?because compute temp/partial 0 1 0 works well.or use fix nvt?any advice will be appreciated.
Kind regards
Rufer
