Dear lammps users,
Hi. In LAMMPS source files such as “pair_lj_cut.cpp" and “pair_dpd.cpp”, the array cutsq is used but is not computed in the same file. This array is clearly the square of the array cut. My question is that if I were writing my own pair style, and the total pairwise force consists of two different forces with different cutoff radius, the pair_coeff would need two different cutoff radius (e.g. cut1 and cut2) inputed. In this situation what would the values of the array cutsq be?
Thanks for your comment in advance.
Chao-jie
July 15, 2016
Dear lammps users,
indeed. the value of cutsq is computed in Pair::init() in the file pair.cpp
the larger of the two. it is based on the cutoff value returned by
PairYourStyle::init_one()
please have a look at the source of pair style lj/cut/coul/cut, which
also has two cutoffs.
This solves my problem, thank you very much, Axel.
