I have been confused about the command "fix rigid".In our work,the indenter configeration is hemisphere .If we employ tersoff potential,the indenter can keep vertical on the direction of loading force all the time .However,when change another potential,namely airebo potential ,the indenter can't keep vertical,it's slant if the load force too small.If the force is large enough,the indenter can keep balance."fix 5 forceitem rigid single force 1 off off on" is my command,forceitem refers to the indenter.
How to make the indenter not lean?
Best wishes,
xianglang
