Hi, everyone,
I have a problem about the log output of NEB calculation.
The accuracy of the potential energy is not sufficient, for there is no decimal fraction.
How can I modify the code of lammps relevant to the neb command to obtain high-precision results (e.g. 2 or 3 decimal fraction)?
Could anyone help me?
Thank you.
H. Wei
Hi everyone,
I have solved the problem.
One should only replace the code in neb.cpp file
fprintf(universe->uscreen,"%g %g ",rdist[i],all[i][0])
with the following code
fprintf(universe->uscreen,"%f %f ",rdist[i],all[i][0]),
then six decimals can be obtained.
See the attachment.
2012/5/2 Haojie Wei <hnrywhj@…414…>
Can you post an example of your lo-precision
output? We use %g everywhere in the code (not %f)
and typically have no problem with precision.
I changed the NEB output precision to %12.8g, the same
as it is in default thermo output for energy (and everything else).
It will be in the next patch.
